Stay for lowered pipe $50.00 |
Max Noise Level | 90db |
Weight | Stock system: 24.33lbs. ( 10.95Kg ) Spectrum Power: 10.88lbs. ( 4.9Kg ) 13.44lbs. (6.05Kg) weight savings. (55% weight loss) |
Increased performance | 4.2 peak HP gain (No loss throughout RPM range) 1.42 lbs/ft peak Torque gain (No loss throughout RPM range) |
1. Titanium full exhaust system (Not a “slip on”) 2. Utilizes your stock two O2 sensors 3. No computer chip or fuel map change required 4. Still use your stock panniers 5. Hand made top quality construction and perfect welds 6. Examine the Dyno data. Compare weight. |
